A while ago i bought a Asus M2N-E M/B.......
When i first bought this M/B it was for a new build, everything was going ok until i started coping my old data over and i got a pop-up baloon saying "Delayed write failed" and the system would then be unusable unless i restart it. i dug around and found a driver update. after installing that it was fine. However recently i have re-installed my pc and have the same error, re-installed the driver update....didn't fix it its only when i copy large files or alot of data at once.Also it's only when writing data. i can run Virus scans on the HDD all day and its fine. Oh and the only drive that this occours on is a RAID 0 Stripe two identical 250Gb Western Digtal Drives. Any help would be greatly appreciated, Thanks. |
Did you update the HDD drivers or the RAID adapter drivers or both?
the .inf file is labeled nvraid, and as far as i know thats the only updated driver for sata/raid on asus's website...
Looking at microsofts knowledge base, they say to set the cache control to 0 via the registry.
Microsoft's Solution Haven't had any errors so far, however haven't had time to properly test it. |
| Thread Tools | |
| Display Modes | |
