Go Back   Technibble Forums > Other Discussions > General Chat
Old 11-22-2009, 10:36 PM
hondablaster's Avatar
hondablaster hondablaster is offline
hondablaster is on a distinguished road
Send a message via AIM to hondablaster
Default Whats specs do you consider old. (junk)
In my tech class alot of the students bring in what I consider junk PCs and fix them up. In thier minds its a fast computer. I understand my desire to build fast PCs gives a me a scewed view of PC hardware so I figure Ill poll what are your thoughts. What is an old PC that you would recommend to a client its time to upgrade.
When I see a PC with any P4 < 3000 mhz and < 80GB < 512 Ram @ DDR < 400. Intergrated graphics.
I dont like the later p4 series simply because they use lots of electricity and run HOT!
CompTIA A+, N+ Certified, Microsoft Desktop Support Technician. http://www.sd-techblog.com
Old 11-22-2009, 10:59 PM
JosephLeo's Avatar
JosephLeo JosephLeo is offline
JosephLeo is on a distinguished road
I don't like the word "junk" since people in developing nations would be more than happy with it. I like to use the word "Deprecated" since it sounds nicer and is fun to say, not to mention it impresses people.
But to me it all depends on the OS that it's running. By default anything older than XP is deprecated.
If the system is XP then anything with less than the following specs isn't good to me, meaning these are the absolute minimum specs in my opinion.
  • CPU: Intel Celeron (Tualatin), AMD Duron & Geode.
  • Memory: 64MB DDR 133MHz
  • HDD: 8GB IDE
If the system is Windows Vista or Windows 7 then the absolute minimum specs are as follows.
  • CPU: Intel Celeron (Prescott), AMD Sempron (Thoroughbred)
  • Memory: 512MB DDR2 400MHz
  • HDD: 40GB IDE
Remember, these are my ABSOLUTE minimum. I would recommend double the horsepower for an actual minimum, and quadruple for an everyday use scenario.
Old 11-22-2009, 11:09 PM
Wow Joseph you make what I called depreciated seem like high end gear. LOL
I understand one mans junk is another mans treasure. And you guys wouldnt be in business if you just recommended new PCs.
I guess my "junk" is sorta elitist. I figure if I cant add hardware to a PC for less than the price of a new one why fix it up. Thats sorta where I get my specs. I can get 1gb ram DDRI 400 for $35 or 2GB DDRII 800 for $35 you start comparing stuff and sooner or later your up to the price of a low end new PC.
About the only thing I could recommend to someone who wants to use legacy stuff is to add RAM and get a bigger HDD and that is if its P4 > 2.0ghz When you start adding graphics, firewire cards, or USB hubs etc. I stay go buy a new one.
Old 11-22-2009, 11:20 PM
JosephLeo's Avatar
Well, those are my absolute minimum specs. That means it's good enough for running one application, and some basic security software and you only use the computer to get on the internet once in a while. Meaning a "Grannies PC"
My real-life minimum specs are twice that, and my every-day use specs are quadrupled of my absolute minimum specs, entertainment would be around the 6 to 8 times area, and then big task like gaming and media editing are in the 8 to 12 times area.
You're junk specs are in fact a little "elitist" being that you still see those specs in some computers only about 2 or 3 years old, and modern day netbooks. I'm not saying you're going to get very far with those specs either, but 80GB is a lot of space believe it or not, and P4's are still considered "powerful"...DDR 2 Memory isn't even phased out yet either- so even if it's 400MHz it's still not bad.
NYJimbo's Avatar
NYJimbo NYJimbo is offline
NYJimbo is a glorious beacon of lightNYJimbo is a glorious beacon of lightNYJimbo is a glorious beacon of lightNYJimbo is a glorious beacon of lightNYJimbo is a glorious beacon of light
XP systems with :
Less than 512mg ram
Less than 40gb drive
Less than Athlon or Celeron CPU
Less than 64mg video card
Vista / 7 with:
Less than 2 gb ram
Less than 80gb drive
Less than 2 core procs or high end single cores
Less than 256mg video card (with gpu)
I stopped screwing around with pathetic machines a long time ago. If a customer brings in an ancient toy I tell them that in a very friendly and respectful way, but I do tell them that.
Old 11-22-2009, 11:24 PM
JosephLeo's Avatar
I would never turn away work. If A customer wants me to run anti-virus on a 10 year old Windows ME machine and I can't pursuade them into a cheaper solution like buying an intel Atom machine then by God I will remove that virus on that 10-year old Windows ME machine....of course I won't remove it on the machine itself, instead I will slave it up to my own bench and then remove it via virtual machine
Old 11-22-2009, 11:26 PM
studiot's Avatar
studiot studiot is offline
studiot is on the way
These 'pathetic' or 'depracated' machines are the ones most likely to be in need of our repair services.
Will not the latest and greatest still be under guarantee?
If it ain't broke
Fix it until it is
Old 11-22-2009, 11:31 PM
NYJimbo's Avatar
Wow, I would not do that for some simple reasons, there are so few people running those kind of machines and I dont need to get "down and dirty" working on them to stay in business. It's just not worth the work when I look at the profits on such a job.
Tommorow, Monday the 23rd, I already have one machine coming in for viruses, one for a solder job on a netbook to allow it to run a hard drive and another for a failing hard drive which needs a cloning and some minor O/S file restores. All of these machines run XP or Vista and are much easier to work with. Why kill myself with "ancient" crap, I send it somewhere else.
  #9
Old 11-22-2009, 11:35 PM
NYJimbo's Avatar
Well, define "latest and greatest" ? I mean I get machines every day with dual core centrinos or 1-2 gigs of ram and 160gb drives that came off warranty a year or more ago.
The 'pathetic' or 'deprecated' machines, by my definition, have been off warranty by more then 2-3 years (not including extended warrantees).
  #10
Old 11-22-2009, 11:45 PM
Im in the frame of mind I rather try to sell a newer PC first and do a file transfer and optimize of some sort. I also have been noticing (well I do far more reading here than posting) that people who try to keep very old legacy machines alive tend to be clients that a successful tech might not want to have (Depending on your situation of course) They will nickel and dime your services and then your going to spend extra time fixing a PC that is slow to respond. Its a snowball effect to a degree.
BTW I dont want to look like some snob if someone gave me A PC with the max spec I originally listed I would not be afraid to work on it. Keep in mind the greater than or less than > < symbols.
