Old 11-13-2009, 05:23 AM
Goraek Goraek is offline
Goraek is an unknown quantity at this point
Default Repartition/Resize system drive
Hey TN'ers,
I was just wondering if there are other partition software that can resize the system drive. I want to be able to increase the size of the system drive. I have seen some of the software out there however it only can decrease not increase.
Can someone please give me some direction?
Cheers,
Goraek
Goraek - TN Newbie
Old 11-13-2009, 07:50 AM
studiot's Avatar
studiot studiot is offline
studiot is on the way
For XP the last version of Partition Magic (8) is the safest. It does not support Vista or 7.
There is a freeware (although you should pay for a business licence) lookalike that is slightly more uncertain, but also does Vista and 7
http://www.partitionwizard.com/
If it ain't broke
Fix it until it is
Old 11-13-2009, 08:24 AM
atlanticjim's Avatar
atlanticjim atlanticjim is offline
atlanticjim is on a distinguished road
I have used GParted.
Patchogue, New York
Old 11-13-2009, 12:28 PM
JD1248's Avatar
JD1248 JD1248 is online now
JD1248 is an unknown quantity at this point
I would use ghost for this. Just do a partition to image create, then you can make a new partition on drive, any size you want. After that you ghost it back, works every time. You also have an added safety factor of having an image if this goes wrong. Partition resizing can be catastrophic!
Old 11-13-2009, 02:59 PM
pappu060 pappu060 is offline
pappu060 is an unknown quantity at this point
U can better try Paragon.PM.10_x32 that can solve ur problem it was tested..it can work xp/vista/win7 in both 32 or 64 bit.
Old 11-13-2009, 04:07 PM
PcTek9's Avatar
PcTek9 PcTek9 is offline
PcTek9 has a spectacular aura aboutPcTek9 has a spectacular aura about
well
You can use PARTITION RESIZER which is freeware. It's from www.zeleps.com. I do recommend you use PING to back up the partition to somewhere else on the network before resizing (just to be safe). PING is a freeware linux version of Ghost. (Ghost for windows is junk, but ghost for dos works great everytime, which is probably why norton included a copy of the last dos version every year with the windows version) Anyway...
Ping (partition image not ghost) is a freeware program. burn it to cd. boot the cd. tell it to take everything on the entire pc, compress it if you like, then store the image on any other pc on your network. ping just works. so far I've never had a single problem getting it to do what it says.
The partition resizer program is cool, it works very well. Just enlarge or shrink the partition. First though I would move all the data to the front of the drive if you are shrinking the partition by doing a defrag with options to relocate files to the front.
Old 11-16-2011, 01:59 PM
bitbytes bitbytes is offline
bitbytes can only hope to improve
Thank you for the tip.
Just to be clear, you would need to delete the old partition > create new partition > then ghost to new P?
Old 11-16-2011, 02:01 PM
Slaters Kustum Machines's Avatar
Slaters Kustum Machines Slaters Kustum Machines is offline
Slaters Kustum Machines is on a distinguished road
+1 for GParted that's what I use and works on Linux and Windows and is free.
  #9
Old 11-16-2011, 02:28 PM
MobileTechie's Avatar
MobileTechie MobileTechie is online now
MobileTechie has a spectacular aura aboutMobileTechie has a spectacular aura about
Easeus Partition Master Pro does pretty much any kind of partition operation you can think of.
