Go Back   Technibble Forums > Site Stuff > Repair Tool of the Week Suggestions
Old 11-10-2009, 10:32 PM
PatrickB PatrickB is offline
Location: Springfield Missouri USA and anywhere by remote control
PatrickB is on a distinguished road
Default CleanWipe - How to completely remove Symantec Antivirus (without entering password)
www.miketechshow.com podcast mentioned CleanWipe recently as a way to remove Symantec AV when the password is unknown.
http://gluek.info/wiki/en/software/symantec-cleanwipe
"The cleanwipe utility is used to completely remove Symantec Antivirus and Symantec Endpoint Protection products."
Searching on "CleanWipe", I see that Adie mentioned it last Spring.
-- Patrick B.
Old 11-10-2009, 11:21 PM
NickCat11's Avatar
NickCat11 NickCat11 is offline
NickCat11 is on a distinguished road
Good to know. Thanks!
Nicholas Catanoso
Garden Greenhouse and Nursery
Avalon Campground
Old 11-11-2009, 01:54 AM
AtYourService AtYourService is offline
AtYourService will become famous soon enough
believe or not usually the password is 'symantec'
Old 01-01-2010, 12:44 PM
Cambridge PC Support's Avatar
Cambridge PC Support Cambridge PC Support is offline
Cambridge PC Support has a spectacular aura aboutCambridge PC Support has a spectacular aura about
is that the one where you need to wipe out the LanManager bit in the registry before you can uninstall?
Old 01-01-2010, 02:20 PM
iisjman07's Avatar
Raymond.cc posted an article on removing Norton without the password, it all basically trails back to one registry key - remove that and poof, your password's gone
Old 01-02-2010, 10:53 AM
TriadPCSolutions's Avatar
TriadPCSolutions TriadPCSolutions is offline
TriadPCSolutions is an unknown quantity at this point
Send a message via MSN to TriadPCSolutions
I could be remembering wrong, but I'm pretty sure I remember using the norton removal tool to take symantec corp off several systems at one of my previous jobs. I recall it only needing a captcha and not prompting for the password of which was forgotten on the systems by the companies actual admins.
Old 01-02-2010, 09:32 PM
iisjman07's Avatar
EDITED to remove link:
First, to fix the password issue, we can start up regedit and from the file menu connect via the network to the remote machines registry. Then navigate to the following key.
"[HKEY_LOCAL_MACHINE\SOFTWARE\INTEL\LANDesk\ VirusProtect6\CurrentVersion\AdministratorOnly\Sec urity]"
In that key make sure the two following values "LockUnloadServices" and "UseVPUninstallPassword" are zero. That takes care of the password asking problem.
Now there's no need for it
Old 01-03-2010, 02:27 AM
iisjman07, What is jlamb.net? Why should we trust an executable from them? I tried going upstream to http://downloads.jmlamb.net/symantec
and to http://www.jmlamb.net/, but found nothing.
Also, a Symantec employee says:
"However, NoNav is no longer supported or used. It was packaged using Symantec's Packager, which is just a self extracting zip file format."
http://www.symantec.com/connect/foru...10x-nonav-tool
One poster in the same thread said that Nonav does not work on v10. Is that true?
Thank you,
-- Patrick B.
  #9
Old 01-03-2010, 03:21 AM
CompConfig's Avatar
CompConfig CompConfig is online now
CompConfig is on a distinguished road
Send a message via MSN to CompConfig
FYI, most do not change this ... the default passward is symantec
