Go Back   Technibble Forums > The Computer Repair Business > Computer Deals
Old 10-18-2009, 07:38 PM
AtYourService AtYourService is offline
AtYourService is on a distinguished road
Default Pre-Order Windows 7 Home Premium Operating System $90, Pro $124, Ultimate $160
Ships 10/22. SuperBiiz.com (eWiz.com) has the Highly Anticipated Microsoft Windows 7 Operating System for Pre-Order on discount with Coupon Code: PUMPKIN15 (Exp 10/31). Free Shipping. Tax in CA.
Discounts after $15 Coupon Code: PUMPKIN15 apply on All Versions.
_________
Microsoft Windows 7 Home Premium 64-bit (OEM) $90
http://www.ewiz.com/detail.php?name=MSGFC00599
Microsoft Windows 7 Home Premium 32-bit (OEM) $90
http://www.ewiz.com/detail.php?name=MSGFC00564
Microsoft Windows 7 Professional 64-Bit (OEM) $124.00
http://www.ewiz.com/detail.php?name=MSFQC00765
Microsoft Windows 7 Professional 32-Bit (OEM) $124.00
http://www.ewiz.com/detail.php?name=MSFQC00730
Microsoft Windows 7 Ultimate 64-Bit (OEM) $160.00
http://www.ewiz.com/detail.php?name=MSGLC00736
Microsoft Windows 7 Ultimate 32-Bit (OEM) $160.00
http://www.ewiz.com/detail.php?name=MSGLC00701
Old 10-24-2009, 11:03 PM
or do this
You can do a full install with a win7 upgrade disk
After performing the clean install, ensure that there are no Windows Updates pending that would require a system reboot. (You’ll see an orange shield icon next to Shutdown in the Start Menu if this is the case).
Then, open regedit.exe with Start Menu Search and navigate to:
HKEY_LOCAL_MACHINE/Software/Microsoft/Windows/CurrentVersion/Setup/OOBE/
Change MediaBootInstall from “1″ to “0″.
Open the Start Menu again and type cmd to display a shortcut to the Command Line utility. Right-click this shortcut and choose “Run as administrator.” Handle the UAC prompt.
In the command line window, type: slmgr /rearm
Then tap ENTER, close the command line window and reboot. When Windows 7 reboots, run the Activate Windows utility, type in your product key and activate windows. It should just work.
There you have it. An easy way to do a clean install of Windows 7 using an upgrade DVD. This is obviously only legal if you own a previous Microsoft operating system that’s supported by the Windows 7 Update program.
