Go Back   Technibble Forums > General Computers > Guides, Tips and Tricks
Old 10-15-2009, 02:02 AM
AtYourService AtYourService is offline
AtYourService will become famous soon enough
Lightbulb Create Bootable Tech Tools USB
This will be an ongoing tutorial for us on how to create a multi-boot USB that will allow you to boot from your favorite live cd , so far I have it working with ophcrack,hirens 10.0,memtest bactrack4, nt pass reset and konboot. Im still learning alot of stuff so bear with me. These bootable usbs are perfect for tech because we dont have to lug around 30 different cds to job sites. and is better to combat viruses and bootkits because you dont have to worry about them being hidden when the system is running live
To start off you will need a usb thumbdrive , im using an 8gb no-name ebay usb drive that i probably got for like $20 2 years ago on ebay.
to start off plug in the usb drive, and type "diskpart" in the run box:
everything in red is what you will type, (we are going to create a single main partition but you can make more if you want. after creating the parittion we will format it fat32)
Microsoft DiskPart version 6.1.7100
Copyright (C) 1999-2008 Microsoft Corporation.
On computer: SCORPION7
DISKPART> list disk
Disk ### Status Size Free Dyn Gpt
Disk 0 Online 186 GB 1024 KB
Disk 1 Online 74 GB 6144 KB
Disk 2 No Media 0 B 0 B
Disk 3 Online 7900 MB 0 B <--this is my 8gb usb drive
DISKPART> select disk 3
Disk 3 is now the selected disk.
DISKPART> clean
DiskPart succeeded in cleaning the disk.
DISKPART> create partition primary
DiskPart succeeded in creating the specified partition.
DISKPART> list partition
Partition ### Type Size Offset
* Partition 1 Primary 7899 MB 1024 KB
DISKPART> select partition 1
Partition 1 is now the selected partition.
DISKPART> active
DiskPart marked the current partition as active.
DISKPART> format fs=fat32 quick
100 percent completed
DiskPart successfully formatted the volume.
#################XP USERS READ HERE #############################
XP doenst let you use diskpart on usb drives so the work around is to download
http://gocoding.com/page.php?al=petousb
run the PeToUSB executable, select the drive, check Enable Disk Format, Quick Format and Force Volume Dismount and click Start.
now that the drive is finished we need to get grub4dos http://sourceforge.net/projects/grub4dos/files/
download grub4dos-0.4.4.zip, we only need the file called "grldr" from the zip , extract it to your usb drive
download grubinst http://sourceforge.net/projects/grub4dos/files/
grubinst_1.0.1_bin_win.zip
open grubinst_gui.exe and choose your usb drive under device name (it should be the same number as the disk you created the parittion on, i.e. disk 3 would be hd3) then click install button
this will install the grub mbr to your usb drive
then create an empty file in the root of your thumbdrive called menu.lst
if you made it this far, your usb drive should now be bootable :mrgreen:
now for the fun stuff
first we're going to add memtest
#########################MEMTEST################
download memtest86 http://www.memtest86.com/memtest86-3.5.iso.zip
extract to folder in root of thumbdrive called "memtest" and extract the "ISOLINUX" folder from the .iso and put it in the memtest folder (7-zip works great for extracting from .isos)
Now Edit menu.lst
Code:
title Memtest86
kernel /memtest86/ISOLINUX/MEMTEST
and save
now test your drive, plug it in a machine and bootup you should be presented with the grub menu and it should allow you to choose and run memtest
#########################NTPASSWD################
First download ntpasspwd http://home.eunet.no/pnordahl/ntpasswd/cd080802.zip
create a folder called "ntpasswd" in the root of your thumbdrive
extract the contents of the .iso into that folder
then edit menu.lst and add the following line below the memtest line
Code:
title Nt Password Reset
kernel /ntpasswd/vmlinuz rw vga=1 initrd=/ntpasswd/initrd.cgz /ntpasswd/scsi.cgz
initrd /ntpasswd/initrd.cgz
#########################KONBOOT################
http://www.piotrbania.com/all/kon-bo...-v1.1-2in1.zip
create a folder called "boot" in the root of thumbdrive then a folder called "floppy"
then extract FD0-konboot-v1.1-2in1.img to floppy folder
add this to menu.lst
Code:
title Kon-Boot-test
map --mem /boot/floppy/FD0-konboot-v1.1-2in1.img (fd0)
map --hook
chainloader (fd0)+1
map (hd1) (hd0)
map --hook
rootnoverify (fd0)
#########################Spinrite 6################
this is a paid app so if you got it, use it
then extract "SpinRite.ima" to floppy folder
Code:
title GRC SpinRite 6
kernel /memdisk
initrd /boot/floppy/SpinRite.ima
more to come!!!!
Old 10-15-2009, 06:45 AM
LunchBox's Avatar
LunchBox LunchBox is offline
LunchBox is an unknown quantity at this point
Nice, job I always loose my patience when wanting to learn/create my own custom USB.
Right now I use UBCD4Win and original UBCD and I use the tool provided to burn it to my USB. It works fantastic.
I've been trying to get WinPE but I can't get a clean copy (they all seem to have a nasty virus) My only copy is beyong repair.
If you know a good source let me know.
I'll come up with the rest of the signature later.
Old 10-15-2009, 07:05 AM
Jory Jory is offline
Jory is on a distinguished road
This is pretty interesting. I might have to try it out.
Old 10-18-2009, 07:05 PM
successfully tried this on my sd card
whats great about this sd card is that its a usb/sd card in one, and it also has a write protect switch so along with being bootable , now i can put my tech toolkit http://www.whatsmypass.com/tech-toolkit-10 on it without fear of a virus will corrupt the files when i plug it in. even though this one is 1gb its large enough to hold my tech tool,konboot,ntpasswd, & hirens
Old 10-19-2009, 05:18 AM
reesk92's Avatar
reesk92 reesk92 is offline
reesk92 is an unknown quantity at this point
hmmmmmmmm i thought i had saw something similar to this and your back ground proves it to me you saw it on hak 5 like i did nice...
they called it a usb multi pass which sounds cooler
try hard and you can achieve anything...(just not as good as me obviously) lol
Old 10-19-2009, 02:30 PM
yep i scour many security sites on new emerging viruses backdoors and exploits
I've been making single bootable usbs for work but multi made it even better
i started looking for a way after seeing the sardu multi av usb creator
Old 10-20-2009, 03:23 PM
0gr3 0gr3 is offline
0gr3 is an unknown quantity at this point
Send a message via AIM to 0gr3 Send a message via MSN to 0gr3 Send a message via Yahoo to 0gr3
AYS where did you get that USB/SD card? I have checked out my local hardware shops and no one carries them.
Come over to the dark side we have cookies :)
Old 10-21-2009, 01:50 PM
Newbie Newbie is offline
Newbie is an unknown quantity at this point
Just did a google search with the jpg name and found this on amazon
http://www.amazon.com/Sandisk-SDSDPH...524497-5579133
1GB priced @ 12.99
Edit:
Even Better. http://www.amazon.com/SanDisk-SDSDPH..._bxgy_e_text_b
SanDisk SDSDPH-004G-A11 4GB/15MB Ultra II SD Plus Card @ 30.04
  #9
Old 10-25-2009, 11:38 PM
eric76 eric76 is offline
eric76 can only hope to improve
Very nice job. Thanks for taking the time to do this tutorial.
  #10
Old 12-15-2009, 04:13 PM
BryanLee's Avatar
BryanLee BryanLee is offline
BryanLee is on a distinguished road
Send a message via AIM to BryanLee Send a message via Yahoo to BryanLee
Pretty nifty...just ordered a 16gb thumb drive. My old 2gb just wasn't cutting it anymore. Looking forward to consolidating some cd's onto usb. Thanks for the nice post!
AeroTek IT Solutions
Onsite & Remote Computer Support serving Oahu, Hawaii
