Your clients or even your own computer may keep restarting for no reason without warning. First of all, when a computer keeps rebooting it can be caused by a wide range of problems, from incompatable software such as Firewalls and Antivirus software, damaged or overheating parts inside your computer or even incompatable peripherals such as printers and scanners. Here are some computer repair tips to help you diagnose the problem.
When a reboot occurs from within Windows XP, your computer will totally restart without telling you what caused it. This is the default behavior when Windows XP encounters a system failure.
To see what the error was you can change the default behavior by right clicking on “My Computer” and choosing “Properties”. Goto the “Advanced” Tab and under “Startup and Recovery” press the “Settings” button.
Under the “System Failure” box there will be a checkbox saying “Automatically Restart”. Untick this box and click Ok.
Next time the system has a failure it will show the Windows error blue screen (also known as BSOD, Blue Screen of Death) and it will have an error code, grab a piece of paper and write this code down.It may look something like this: Stop 0×0000000A or IRQL_NOT_LESS_OR_EQUAL
You can view our easy to read stop error troubleshooting guide or you can search Google for the stop error or search the Microsofts Knowlege Base to find out what this code means (its a bit technical though) and possibly find out a fix.
You can also check to see why your computer had a failure by checking the Events log for error messages. You can see the Event Viewer by going to Run and type “eventvwr”.
Another cause for random reboots is that the computers processor is getting too hot. To check this, enter the computers bios during boot (usually by pressing Delete, F1 or F10 when the computer just starts) and there will be an option about the computers temperature (often under “PC Health”).
This should show you the current temperature of the computer and the emergency shutdown temperature. The emergency shutdown temperature is a safeguard for when your computer gets too hot it will shut itself down to prevent damage.
You can either raise the shutdown temperature or switch it off completely, however be warned that you may damage your computer (or the clients) if the computer gets too hot. If the temperature was causing the reboots then you should consider getting better cooling for the computer such as more powerful CPU fans and more case fans.
Articles
Blogs
Kits
Forums
Thanks so much for your advice, but my computer stills restarts everytime i try to start the registry. i think i have an advanced type spyware running on my computer that cant even be detected by antispyware,or what do you think?
Well mine is much more complicated, I cannot run a virus or spyware scan without it shutting down and I have recently noticed a folder in my c directory named “copy of windows”. Ihas 3 sub folders as follows 1)mbsa 2)media player 3) startup inspector this one says by Igor Pavlov. The folder says it was created the day I installed Windows xp, 4-26-05 and frankly I do not remember ever seeing this before. Before i can restart I have to wait a few minutes. All my drives checked out okay, the cpu is fine, either someone has hacked into my pc or maybe my power supply is going, but usually a good sign for that is I cannot use my cd burner to burn a cd which in the past would cause the pc to freeze, hence not enough power, but I burned some cd’s last week and this has been happening for over a month, except for the last 3 weeks it has gotten worse. Any ideas on this extra directory?
I hate XP, 98 I knew and could fix, but XP drives me crazy! I am ready to call Microsoft.
One other note, the last auto virus scan I had on record was 2-8-07 and my system restore only goes back that far now, it used to go back further! Help, ready to toss my pc. Thank god for my laptop!
Your problem can be caused by a bad memory.Or if you upgraded your memory recently make sure your motherboard can handle the memory you installed last.Some computers require memory to be installed in pairs.two 256s or two 512s.i had the same problem with my HP desktop.I had one 256 and one 512.I removed one and that solved the problem
my pc restarts after around 30secs after i reached desktop. I am able to continue in safe mode and it doesn’t restart anymore.
in this case? what could be the cause of the problem? is it a hardware or software issue?
thanks
I have been experiencing the same problem as Aris, my computer will startup every day, run for a while, and for no apparent reason, with no warning or any files being opened or altered, the computer restarts, I log back in, and it restarts, usually does this 3 times, then runs for a while until the next random reboot.
Some of you guys should either try taking out one of your memory sticks or else buy a new PSU.
I’ve been having the same problem with restarts, but mine started when I installed the latest Nvidia drivers, and now I can’t get it to stop even after rolling back to an older driver.
Check the wiring on the power on LED and reset buttons if you toggle them and the cpu fan begins to run then your wires are at fault and you will need a new computer case. It happened to me after I had tried almost everything else. You cannot just replace the switches the whole case needs to be replaced but they are cheap and maybe even get a new power supply, they can be had for less than fifty dollars.
I was given a great little PC w/XP but when I turn it on, it will continue rebooting after desk top just shows up. It will do this automatically all day until I turn it off. I am not able to get to any programs…I have checked all connections. It only has one memory stick…a 256…John in payson, AZ johnnygo@localnet.com
ok i went to RUN and typed ‘eventvwr”
BUT I DO NOT UNDERSTAND ANY THING da report sayin…. helpppppppp plz
My PC is acting really strange, I’ve not replaced anything on my PC for ages but now for no reason a couple of weeks back its started restarting itself every couple of hours.
Now it acts like its restarting ie. programs shut down and the XP tune plays but the screen stays as if it didn’t do a thing.
Please help….
I had some rolling blackouts yesterday while i was running my desktop. When I tried to turn it on after the blackouts were over, it would get to the XP loading screen(the one w/ the bar going across), and reboot. It keeps doing this and always reboots at the exact same place. I don’t know if my HDD is fried, or if windows just has some corrupt files. Is there any hints that could lead me to the problem? One of my co-workers also said it could be my power supply, but I’m thinking that if it created a short in my power supply, it wouldn’t reboot at the exact same point every time.
Also, if it is my windows that is corrupted, is there any way to install windows again w/o losing all my information/installed programs?
I have 2 computers now that keep restarting. i get to the blue windows screen and and it reboots. it will not boot in safe mode or any other type of mode. I know it is not any hardware problem. it got to be a software problem. on both comps before this problem started. i updated AVG, Adaware, and SuperAntiSpyware. So there have to be Issues with one of these programs. If anyone can help me it would be appreciated.
jeff
Hi i have a new computer and it keeps restarting before the monitor even turns on. I have tryed it with a differant power supply does then same changed the graphics cards and still the same and the ram..PLEASE help its urgent to get this computer working..
Will be much appreciated !!!
My computer keeps restarting it loads to desktop and it restarts so how do i fix that problem?
hi some off you sounds like you are over heating open the case and see if there is loads of dust also check all case vents if there is dust get a hoover and clean all parts however do NOT touch and parts instide the computer this may cause a static charge and totaly kill you computer if it is done right it may solve the problem as dust traps heat ,it can not escape, is this works also try to get better cooling, add a fan or two or get better cpu fan if it is overheating
hope it helps
hi Jeff if you can not evan boot insafe mode then there is only one action to do and that is a full format. Sadley this will wipe everything off your hard drive and you will have to re-install your OS but it should solve your problem
Hi Dan your problem is a bit more difficult to do as it sounds like you need a new motherboard look on the internet some are not too badley priced but it sound like you need it
0X0000008e 0XC0000005 0X805B0E09 0XAA4CCC1C 0X00000000
i found this error on the blue screen please help me
My computer is restarting it’s self and everytime I try and turn off the automatic restart it reboots before I can get to it. I think it has something to do with an antivirus program that is outdated. But even when I go to the control panel and try to delete it, it reboots itself, it’s almost like it freezes until it reboots or something.
I need help I have no Idea what to do next.
I have solved my problem by your help and i am very much thanks from my side.
“shutdown -a” on the run command (without quotes) will stop the computer from automatically rebooting as well!!
At first download avg, if you can’t perform a scan. Then what you could to take your harddisk out put in another computer and run avg on that harddisk
hi,i have a computer it keep bringing me to the window blue screen and restarting whenever i am in the middle of a game…..i thought it is cause by over heating…but when i left my com case open..with a fan blowing into the cpu….and try playing game agin…the same problem occur….so is there anyone out there who have a solution to this problem….?it would be great help
hi i got the bebo virus on my computer last week and now when i turn it on it says unable to open windows file corrupted and then restarts itself and just gets to the same stage each time i switch it on be grateful for any help on how to fix this thanks
Thank you for the help found out what my problem was right away.
I am running Windows XP Home Edition and this was my error:
PFN_LIST_CORRUPT
0×0000004E (0×00000099, 0×000BF196, 0×00000007, 0×00000000)
Problem: Bad RAM
Easy fix
I have an issue! My computer keeps rebooting. I bought new memory and it still reboots. I leave it off for a few days and it goes all the way up to the Windows XP password to logon and when I enter PLEASE HELP!!
What happens for me is that I run a program called San Andreas:Multi Player(its a multi player mod for GTA:SA) and when i start to lag really bad, my computer will restart…after i log back in it says:
“Windows has recovered from a serious error”
Can you tell me why its doing this please?
Jack
hey i need help with my windows xp…
ive read the post… one problem though, the computer restarts at about 10 seconds after logging in the current user. whats worse, it evens shuts itself down even when in safe mode.
it shows multiply error messages before it restarts and it doesnt even wait for me to confirm…
one of the messages i think says “cmd.exe cannot run because windows is shutting down” and the list goes on with a couple more “.exe’s”
what could be possibly wrong? how can i fix this without reformatting my pc? i have important files in it… and i can’t even reach it…
help is appreciated
I had the problem when the computer loaded to my desktop, it restarts. It can do this all day long and it’s so pain in the ass!
I think if I use Windows Recovery Console, it might help. I used the Chkdsk command /p and i found several problems for my hard drive. So now, I’m trying Chkdsk /r to revocery it. I don’t know how well it goes but I’m hoping it goes well.
Plus, I have multiple hard drive. My Windows installation is on G drive and my old Windows is on C drive. I think they make conflict with each other, I don’t know.
Help is greatly appreciated.
Mine keeps restarting. I can’t get in safe mode, and when I put the windows cd in, it says can’t find NTDLR, or something like that. I’m not very technical when it comes to computers. Is my computer finished.
Oh, and when I disable the automatic restart at the first sign of system failure, then I get a message: Insurmountable boot volume.
So basically, even when I click on safemode, it restarts the computer, I can’t even get to the desktop, and the windows cd won’t work either.
Can my computer be saved?
Hi evrybdy
my pc has been infected by ymxf2.exe cloaked malware. I’m unable to use Prevx too. can anyone help me out?
hardware defectiveness might be the cause…
savvy…
memory modules!!
Hi guys
I recently restarted my computer and got some weird screen showing “Inserting and index with id (numbers were something like 8000-10000) from $SII of file 9″ something along those lines and after a while the screen went away and now the computer is constantly restarting on its own untill i shut it off. I have about 10-20 seconds before it restarts once it hits the desktop. Any help would be greatly appreciated
not one but two of computers are doing the same thing. Both of them restart on its own. The last thing i did on both of them is the windows update from microsoft. One of them get to the desktop and then restarts. The other one stays on for like 20 minutes and then restarts.
Any suggestions!
I have an XP Pro P4 computer that is shutting down after about 2 minutes UNLESS Windows Media Player is playing, then it will stay on for hours and not restart at all. I’ve tried numerous fixes, if anyone has a clue please share it. I’ve replaced power supply, processor fan, all fans are working, cleaned it, checked for viruses, etc. and changed the video card.
when i turn on my computer it goes to gateway and keeps restarting plese help
